Old 04-11-2024, 08:22 PM #1
bzizzi's Avatar
bzizzi bzizzi is offline
bzizzi will become famous soon enough
bzizzi's Avatar
Front Needle Bearing TSB
Well, way back in 2013 I had my front differential replaced on my 2011 SR5 under warranty because front end noise that was diagnosed as left front needle bearing failure.
I had to take 4R back three times before dealer and Toyota found the issue, back then there was no TSB yet. When dealer took apart differential they found needle bearing was pretty much destroyed and axle was riding on the diff housing and fluid was seeping out of seal.
Fast forward, my 2020 TRD ORP had the same noise from day one, I took in for service and was told this is normal, noise went away when I engaged 4WD.
Couple weeks ago I traded that 2020 in for a 2024 and so far this one is completely silent of any noise in or out of 4WD. I'm just curious what Toyota might have done to fix this issue or am I just lucky for now. I will know for sure as miles increase.
bzizzi is offline   Reply With QuoteReply With Quote
Old 04-13-2024, 04:02 AM #2
wing2 wing2 is offline
wing2 is on a distinguished road
Sounds like there is an updated part. He talks about it in the four wheel drive section of the video, at the five minute mark.
2010-2020 Toyota 4Runner buying guide - YouTube
wing2 is offline   Reply With QuoteReply With Quote
Old 04-13-2024, 08:56 PM #3
Soulprogression108's Avatar
Soulprogression108 Soulprogression108 is offline
Soulprogression108 is on a distinguished road
I'm interested in what the noise is? I have a 2011 Trail Edition that has a light squeek sounds like it's coming from drivers side wheel. 90% not brakes. They were done not that long ago and braking doesn't effect the sound. Just hear it most of the time when cruising at 30mph or so a little more still there. Faster maybe it's too noisy outside to hear, but slower it's not typically there. I will check wheel bearings soon, but I've heard driver's side needle bearing goes out in a lot of this year T4Rs and Tacomas.
Current: 2011 Trail Edition T4R
Bilstein Leveling Kit: 6112's and 5160's
TRD 17" Gold Wheels 31" TA's
Sold:1994 T4R 22re 4x4 MT
Aluminum Weld 15's and 31x10.5 BFG ATs
Soulprogression108 is offline   Reply With QuoteReply With Quote
Old 04-14-2024, 10:25 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
The T-SB describes the noise as a "cyclical groaning/grinding noise", so your squeak would not be caused by the needle bearings.
Granted, the T-SB covers 2016+ 4Runners but I would think the noise would be the same. (T-SB-0012-19)
The T-SB also states that the needle bearing noise goes away when 4WD is engaged, so t hat would be another way to check.
Edit: Going through my records, there is a T-SB that applies to the earlier 4Runners, FJ Cruisers, and Tacomas, all the way back to 2004: T-SB-0026-15.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-14-2024, 10:30 AM #5
1. The T-SB for this issue states there was a production change that fixed the issue, so your '24 should not have the problem.
2. The T-SB states that the noise goes away when engaging 4WD; that is one of the ways you diagnose the issue.
3. I am always leery when a dealer tells me something is "normal" when you have a problem described in the T-SB. (T-SB-0012-19).
Edit: The T-SB says the problem was fixed by a new differential carrier assembly. It gives the new and old part numbers for that.
Old 04-17-2024, 12:34 PM #6
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
The needle bearing from hell...
The craptastic needle bearing noise/vibration is a known issue with the 4runners. The factory needle bearing is on the drivers side only as the passenger side uses a different system...WHY TOYOTA???
That said, at 93000+ miles I had mine replaced with an "oil bronze" bushing kit by Dallas OffRoad. The buzzy vibration in the steering wheel is now totally gone.
Interesting side note, the 2019 that my daughter drives (bone stock SR5) with about the same mileage exhibits none of the vibrations mine did.
Perhaps the issue is more pronounced when we add lift and weight to the front ends...just a thought...
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb rear springs, DrawTight Class IV frame hitch, Method Racing 703 Bead Grips. 33x10.5 -17
AMLOR is offline   Reply With QuoteReply With Quote
back , bearing , front , needle , noise
2020 4R needle bearing bzizzi 5th gen T4Rs 51 01-11-2024 09:24 PM
Needle Bearing Issue xmytruck 5th gen T4Rs 8 02-15-2022 01:38 PM
Front Differential needle roller bearing replacement LTDSC 4th Gen T4Rs 34 02-16-2020 10:00 PM
Evap codes, needle bearing/wheel bearing and tires Johns06yota 4th Gen T4Rs 15 08-05-2018 11:10 AM
Needle Bearing and CV Axle kremlon 3rd gen T4Rs 11 04-27-2017 09:26 PM
